New 2 the game need help?
Old Mar 31, 2004 | 02:17 PM
ClipThis's Avatar
Default New 2 the game need help?
I have and 90 Eclipse automatic and my won't start no more because it won't stay in Gear and i can't seam 2 keep it tight
Old Mar 31, 2004 | 02:27 PM
SpyderGS's Avatar
Wow, complicated problem. Well it soundsmechanical, so you'll have to take out the center arm rest area where the shifter is. Just take of all the plastic panels and look under there. It's kinda hard to tell you exactly what to do, ya know, it's like a "you have to be there" kinda thing. But look at the shifter and see if there are any broken cables or anything atttached to it. If you can press the shift lock button all the way down and it sticks or deosn't pop out all the way, then the shifter is broken. If the button pops out like normal, but the lever(shift stick)won't stay in gear, then it may be a broken peice on the baseor cable. Like i said, it's hard to tell you what to look for since i can't see it. But if you have time, just open it up and look around. Sometimes the hardest problem is caused by the simplest thing. If you can't find anything wrong, just write back and explain it a little bit more. Hope this helps.
Old Mar 31, 2004 | 04:59 PM
91eclipse's Avatar
i have no idea what to tell-yeah there...
Old Apr 5, 2004 | 02:09 AM
ClipThis's Avatar
good lookin on the advice i gotta it poppin
03eclip
Apr 21, 2015 08:20 PM
letsmakeadeal
May 18, 2012 01:09 PM
dienekes1982
Feb 25, 2007 02:08 AM
tidus10
Jan 17, 2007 06:52 PM
