new belts
Old Aug 19, 2005 | 09:13 PM
g9s5t's Avatar
Default new belts
ok i just replaced the power steering belt on my gst because it snapped.... it squeaks.. bad... does it have to break in?? why is it still squeaking a week after a replaced it?!... what do i do?
Old Aug 20, 2005 | 03:31 AM
DixonsGst's Avatar
Default RE: new belts
check to make sure that its not too loose or if its too tight it would make noises also. It could be your p/s pump squeeling. Just put some lucas rack and pinion fix in your power steering resevoir and it should stop.
Old Aug 20, 2005 | 04:58 AM
DSMTalonAWD51's Avatar
90% of the time squeaky belts are the result or improper tensioning. try tightening/loosening it to spec
Old Aug 20, 2005 | 12:14 PM
g9s5t's Avatar
how do you tighten loosen a belt??
Old Aug 20, 2005 | 06:11 PM
g9s5t's Avatar
ok i think my power steering belt is rubbing up against my timing belt cover?!... hmm what to do?
Old Aug 21, 2005 | 07:04 PM
g9s5t's Avatar
b
embassy17
Apr 24, 2006 06:14 PM
mr2masta
Apr 2, 2006 11:49 AM
letsstophere
Feb 12, 2006 11:47 PM
00GalantMan
Feb 6, 2006 01:31 AM
mesaboogie18
Oct 8, 2004 09:51 PM
