next step on GSX
ORIGINAL: skyline
What's the difference between the 6 and 7 bolt engine besides the bolt pattern?
ORIGINAL: EMonz57
Im thinking 6 bolt swap soon too if its not in there already
guys i hate to say it but the issue is with the berrings not the crank a soft crank will result in throwing a rod becuse the berrings from the rods will wear the crank and the knock from that will let you know it has happened which is not what crankwalk is crankwalk is a falure/sloppy crank berrings and the crank walkes itself out of postion this has been addressed by mitsu and is fiked by putting in a better crank berrings which will make the 7bolt walk just as much as a 6bolt yes i said it all motors can crankwalk. the fact that he has new rods sould meen that all berrings are changed in the lower end so dont worry about crankwalk it is very un-likly that it will happen whith the internal mods you have now low oil pressure sure this may be but with a full rebuild which should be done when the bottom end is built up the oilers and bigger oil pump should be put in. the fact is that his motor sould be fine with the internals he has put in dont worry the poor guy about issues that are not rellivant to his motor.
ORIGINAL: get435
I think you missed the whole point of the post according to mitsu as well as many macinest i have talked to the berrings were the issue with the 7bolt block once replaced with a good berring not the POS ones from mitsu the crankwalk issues is lower to the point of any motor and dont thina 6bolt cannot crankwalk ANY MOTOR CAN CRANKWALK it just so happens mitsu put some ****ty berrings in the 7bolt. now cack to what i said if the rods were replace the berrings were replace if they were not take it bcak because you are asking to throw a rod.
ORIGINAL: get435
