no compression
This includes all Eclipses, and Talons built from 1995-1999
no compression
Nov 11, 2007 | 03:13 PM
estraw
Dec 2005
RE: no compression
haha mike i just realised this was you lol
estraw
Visit estraw's homepage!
Find all posts by estraw
Nov 11, 2007 | 03:22 PM
artificialboostin
Mar 2007
RE: no compression
rings cant be shot i have 35k on the engine
artificialboostin
Find all posts by artificialboostin
Nov 11, 2007 | 03:37 PM
estraw
Dec 2005
RE: no compression
you said your head was fine, unless your cylinder walls are cracked i cant really think of anything else that could be wrong
estraw
Nov 11, 2007 | 06:05 PM
dsm1990gsx
Oct 2007
Pa
RE: no compression
If compression testwas bad, do a cylider leak test. That will tell you where your problem is.
dsm1990gsx
Send a private message to dsm1990gsx
Find all posts by dsm1990gsx
Nov 12, 2007 | 09:10 AM
TheEngineer
Jan 2006
RE: no compression
If your getting no compression on all 4 cylinders your either doing the compression test wrong, you have worn piston rings, or your timing is off
TheEngineer
Send a private message to TheEngineer
Visit TheEngineer's homepage!
Find all posts by TheEngineer
For aspirated Power More Compression 4g9series
Powertech
06:35 PM
no compression
5Tizzle
Feb 14, 2006
09:17 PM
Grinding Noise, Low Compression
iceman
12:00 AM
Compression
TheMatt06
1st Generation
02:42 AM
Compression Tester
vertstanggt
12:13 AM
Tags
1995
20
95
98
bent
compression
cranks
cylinder
eclipse
gs
intake
mercury
mitsubishi
sable
valve
valves
Back to Subforum
View Next Unread
Help! Alternator Belt
11:11 AM
