No ground going to injectors, need wiring diagram...
Old May 3, 2007 | 03:45 PM
t4_gsx's Avatar
Default No ground going to injectors, need wiring diagram...
Well, someone hooked my jumpers up backward, frying a 100amp fuse. When they were switched back around the car started but died after the cables were removed because the fuse controlledthe alt. I went to start it myself after the fuse was replaced, and it wouldn't fire. I have no ground going to the injectors, just power. I have checked this with a test light and a noid light(which shows it wouldn't fire)
So, I need a wiring diagram so I can check my relays. I am guessing it is either a relay or my ECU, which a relay would be easier to check before replacing my ECU alltogether. Any information would be appreciated! Thank you, Steveo
Old May 3, 2007 | 03:56 PM
Dusty Eclipse's Avatar
Default RE: No ground going to injectors, need wiring diagram...
First try www.vfaq.comor www.roadraceengineering.com
Old May 3, 2007 | 05:36 PM
t4_gsx's Avatar
Couldn't find anything on those two websites including a couple others. I just need a link to a complete wiring diagram, unless someone knows which ones to check before ruling that the ECU is bad.
Old May 4, 2007 | 01:26 AM
silvercoupe97's Avatar
If you have a Haynes/Chiltons manual, check your ignition transistor.
3000gt16
Apr 1, 2021 02:26 PM
xLoveMeXoTenderX
Sep 5, 2007 02:27 PM
RXtreme8
Feb 9, 2007 12:51 AM
Maichael
Jul 6, 2006 10:38 PM
Nv2hrd
Dec 26, 2005 01:30 PM
