No oil pressure
Old Sep 1, 2006 | 12:38 AM
Nubiebubie_GSX's Avatar
Default No oil pressure
Started car drove it from my neighborhood and got to the first light and noticed my stock oil pressure guage was pegged all the way down. Normally after the car is nice and warm and at idle its like a quarter way up from the bottom and driving it goes to about half. I looked around for leaks and saw none. Could this just be a sensor or something simple.
Old Sep 1, 2006 | 04:10 AM
2nd g eclipse gst's Avatar
Default RE: No oil pressure
my cars doing the same thing but still havent found out whats wrong with it but sometimes mine will creep up alittle bit but goes back down all the way i dunno????
Old Sep 1, 2006 | 09:20 AM
id say its something wrong with the stock guage. Id see if you can get a oil pressure tester or have a shop test it for you to see. If it still reads low pressure then it could be the pump.
Old Sep 2, 2006 | 02:06 AM
well today i jacked the front end up and peaked around.. saw a loose wire that connect to the oil filter area and decided to attach it to the closest thing that would hook on and it works now. Jack ur car up andhave a peak..
Old Sep 2, 2006 | 04:47 AM
98eclpsrider's Avatar
ORIGINAL: Nubiebubie_GSX
it's the little things that makes the big things work
FlipNNVH
Oct 11, 2006 12:52 AM
trader eds
Mar 2, 2005 03:03 PM
EclipseGSRoadRacer
Oct 17, 2004 03:29 AM
quinny
Oct 5, 2004 06:01 PM
ecwfan
Jun 28, 2003 12:09 PM
