no power below 3500 rpm?
Old Jan 29, 2006 | 08:21 PM
Default RE: no power below 3500 rpm?
Yea the vibration in low rpm's is the awd, i also had a tsi-awd and bad suspesion combined with AWD will cause that. As far as the sluggish and the bad gas miles i'm not sure. I know that when i bought my car it ran like #### then i replaced the plugs AND wires and it was fine. I suggest replacing the wires also. Another thing that i have heard is the MAP sensors on these cars are know to break. That may attribute to it since a bad reading could change the amount of fuel being added.
Old Jan 29, 2006 | 08:27 PM
5Tizzle's Avatar
anybody know how much a new map sensor is?
Old Jan 29, 2006 | 08:29 PM
i replaced mine and i think it was around 100. Its just a very small part that goes on top to the intake manifold.
Old Jan 29, 2006 | 08:30 PM
BTW you should be able to get it at any parts store (autozone, ect.)
Old Jan 29, 2006 | 08:31 PM
TheAdvocate's Avatar
Taking off in to low of a rpm will do that.. So if you take off with to low of a rpm with a fwd it would shake too... You just need to take off at a little higher rpm..
Old Jan 29, 2006 | 08:34 PM
5Tizzle's Avatar
well right now im not so much concerned with the taking off and rattling thing, its the 8 effing miles per gallon that has got me pissed off right now.
Old Jan 29, 2006 | 08:36 PM
Yea i had my car for 2-1/2 years and i never fixed the rattling thing. Most of that problem comes from the suspension.
Old Jan 29, 2006 | 08:39 PM
5Tizzle's Avatar
ive had a 4wd car before and i KNOW it shouldnt act this horribly until halfway up the rpm meter. Something is wrong and i know it.
Old Jan 29, 2006 | 08:45 PM
5Tizzle's Avatar
oh yeah, also after i put the new plugs in and drove around for a while i took one back out and it was covered in dry dark grey carbon type stuff.....The car sat for 2 years before i bought it. Could it just be all gunked up or something?
Old Jan 29, 2006 | 08:49 PM
I'm not sure if this woul have anything related but i would read it and see if it helps
https://mitsubishiforum.com/m_42371/tm.htm
The part on detonation. Once again not sure, just a hunch.
