No Spark...
Well my car is not getting any spark. The battery had died.. me being an impatient kinda guy rounded up a couple friends and have them give me a push to try and bump start it... it never started so i left it and stuck the battery on charge... now the i go to start teh car and it turns over... but engine does not start. I pull all the plugs all drenched in fuel so i clean em up and put them back in... nothing. So i check all the fuses... found nothing. So i reset the ECU... nothing. I get fuel... but no spark. Any ideas?
Stick each plug wire on your tongue... LOL j/k. Check the connections at the coil pack (The plugs that go in not the plug wires) and see if they are corroded at all. If so then get a flat fingernail file and some electric connector cleaner. Check your battery terminals as well for corrosion and tightness. If they aren't making a good connection it will also inhibit a spark. And finally you can check for leaping sparks. When dark have the hood up and a buddy or family member crank the engine. Watch the plug wires for arcy sparkies coming from the plug wires.
ORIGINAL: Sebba
I have plenty of battery power if thats what your asking... the car wouldnt turn over otherwise LOL
