Oil in #4cyl rebuilt eng?? WTF
Old Mar 20, 2009 | 11:05 PM
Regardless. If all 4 cylinders were 125psi, then you have a problem.
The slowness to start shouldn't make a difference. Once the needle on the compression tester stops moving, that is IT.
Old Mar 21, 2009 | 11:37 PM
tjbiker031's Avatar
unless i missed something batteries don't have anything to do with the compression of an engine, they just provide electrical. and if the starter is on doesn't matter either. Seriously, tear apart you block and find out what the problem is. you got a serious problem for the compression to be that low. your friend doesn't know what hes talking about.
Old Mar 22, 2009 | 12:10 AM
I bet the piston to wall clearance is all f-ed up
Old Mar 24, 2009 | 09:00 PM
profitwho007's Avatar
Question well i will keep you posted
Im starting the break down this weekend. Im mad that I cant find the guy who did the work. he gave me a one year warty. on the job! I am thinking of paying for a PI to find him. But the car runs good all but the fuel cut at 5000 if I floor it. but normal dirving its fine.
Old Mar 24, 2009 | 10:22 PM
tjbiker031's Avatar
did you have a local shop do it or just some guy? And as for your fuel cut issue....go to the link---->http://www.dsmtuners.com/forums/freq...-fuel-cut.html
that should help you out and that site has insane amounts of information for just about anything you can think of.
Old Mar 24, 2009 | 11:32 PM
I bet it isn't fuel cut, I bet it is just because of the low compression.
Old Mar 25, 2009 | 03:17 PM
Red face mobile mech
well the guy that I got to do the work has done stuff for me in the past. He was listed as one of a million mobile car fix it guys. I took it to his shop and got the car back 4 mo later in bad shape ohhh check eng light came on with code for a TPS. Thanks for the link I will look it up. But would low compression cause fuel cut? If I ease into the gas it will pick up speed just fine just not insanely fine how I like it lol. This Fuel cut thing could be MAS I Got no code for it but my buddies laptop showed no reading from the MAS when we pluged it up?
Old Mar 25, 2009 | 03:46 PM
It was just a misfire caused by low compression, I'm betting.
Old Mar 25, 2009 | 05:01 PM
dsm1990gsx's Avatar
Ok well since compression is low, do a wet compression test and follow that w/ a cylinder leak test.
Btw when you did the compression test did you have the pedal to the floor, then crank it?
Old Mar 25, 2009 | 08:44 PM
Cool test
yes foot was to the floor. I will try the test you told me about before I break things down. Testing tomorrow Stay Tunnnnnned....lol I made a funny..
