Oil leaks in a 420a manual
Old Aug 20, 2007 | 07:05 PM
Catch22!'s Avatar
Default Oil leaks in a 420a manual
Have a moderate amount of oil on the transmission side of our 67 RS 420a manual. Pan is dry. What are the typical sites of oil leaks in the eclipse? Any recommended fixes would be appreciated.
Old Aug 20, 2007 | 07:12 PM
sk8dudety's Avatar
Default RE: Oil leaks in a 420a manual
wow, a 67 eclipse?? thats the oldest ive ever seen em come haha, jk... check your head and your valve cover
Old Aug 20, 2007 | 09:56 PM
nick_200321's Avatar
if it is leaking from the tranny check your CV seals and Rear-Main seal, but to get to the rearmain, you need to take off tranny, clutch, flywheel, and pressure plate.... my tranny was leaking and the spring in my rear main seal was horrible, it should be very tightly in there...
Old Aug 20, 2007 | 10:54 PM
itsme71190's Avatar
directions on how to take tranny off. i got u. ive done mine. is a pain. but it was fun
Old Aug 21, 2007 | 06:08 AM
are you asking for directions on how or saying i should tell him how??
Old Aug 22, 2007 | 09:45 PM
Catch22!'s Avatar
Thanks All
Being new to the Eclipse, thought there might be specific areas that leak.This is my son's car. I just do most of the mechanicals for him (how is that for adad). Inormally work on the two MG's I own and know thatMG;s leak oil as part of the engine design (not kidding about that. No rear seal in my 1950 TD, just threads on the rear of the crank to"sling" theoil back into the engine)
At this point, I was not planning to pull the engine. it does appear to have a valve cover leak on the driver side. That could very well be where the oil is coming from. Any tips for putting the valve gasket in so it does not leak?
Old Aug 22, 2007 | 09:50 PM
not really, just make sure when you pull the bad one there is none of the gasket stuck to the head or inside the valve cover or you wont get a tight fit..
Paquita13
Jun 14, 2013 02:34 PM
jason clipse
1st Generation
Nov 8, 2009 08:42 AM
KirstenLaBarb
Nov 27, 2006 09:32 PM
shooster
Sep 8, 2005 08:02 PM
mike350z
Jul 16, 2004 09:22 PM
