oil pan
Old Mar 23, 2006 | 01:55 PM
novetek's Avatar
Default oil pan
Im going to change my oil pan seems to have a leak is it difficult or basic drain oil unbolt pan change gasket install new pan and add sealant?help please damn and i just change my oil pressure switch last week because that was squirting out oil all over my work parking lot it cost me 170 bucks.thanks
Old Mar 23, 2006 | 02:16 PM
Sanguinius's Avatar
Default RE: oil pan
I can't remember if there's a crossmember under the oil pan on the eclipse or not... If not then it's a simple unbolt, clean the pan and mating surfaces, check the oils pump mesh screen, put the new gasket and a little bit of sealant on and go. Make sure when you do this you allow ample time for the sealant to set before adding oil or it will serve no purpose.
Old Mar 23, 2006 | 02:26 PM
novetek's Avatar
Default RE: oil pan
yeah i think there is a cross member so it shouldnt take more than a 1hr right
Old Mar 23, 2006 | 02:35 PM
Sanguinius's Avatar
Default RE: oil pan
Again depends how the crossmember and oil system are set up. You may need to disconnect the motor mounts and lift the engine to get the oil pan out. May only have to lift it a little bit but you'll have to look at where the likely place the oil pickup is and how much interference there is in the way of geting it out.
Old Mar 23, 2006 | 03:02 PM
eclipseo's Avatar
Default RE: oil pan
I just did this two weeks ago for my turbo oil drain hose, and You need to remove the downpipe and unbolt the crossmembers front and rear bolts you can leave the rubber mount hangin that in the middle, you will not have to jack the motor up and you don't have to remove the oil filter either, and just drop the pan down, the oil pick up hangs about 5" in the deep part of the pan so don't hit that.
Old Mar 23, 2006 | 03:58 PM
slow420a's Avatar
Default RE: oil pan
Ya its a paint in the but, make sure you use rome rv sealent.
Old Mar 23, 2006 | 04:05 PM
Sanguinius's Avatar
Default RE: oil pan
And remember to drain the oil first lol.
Old Mar 23, 2006 | 05:16 PM
RCJr9186's Avatar
Default RE: oil pan
i just took my oil pan off of my 99 GS 2 nights ago. i didn't have to take my downpipe completely off but did take the front 2 bolts off, after that it bent enough from the back to get the pan out. i don't know the name of it but i did have to take that long metal piece off that starts in the front by the front motor mount and goes back about 4 ft... i put my jack on the trani to keep it up. after that, just took the bolts off the oil pan and slid it out (did this to replace the gasket). since im always up for leaning new stuff, what is the metal piece that i am doing a terrible job of describing?
Old Mar 23, 2006 | 09:04 PM
slow420a's Avatar
Default RE: oil pan
lower brace for the motor mounts... or crossmember what ever rings in your ear better.
ccernst
Jan 14, 2011 08:38 AM
Vadimus
Nov 26, 2010 12:13 PM
tidus10
May 17, 2006 08:50 PM
tidus10
Apr 7, 2006 05:39 PM
modestmitsu
May 13, 2005 05:31 AM
