oil in spark plugs??
ORIGINAL: TheEngineer
yea it the labor that will kill you cuz most shops are looking at around 10 hours of work at least.
well first of all i would make sure thats the problem. Do a compression check and see if any are bad. But the reason its such a long job is because to do it you have to remove the head right off. Then while you have it off there is stuff they will replace (which you should anyway) like the waterpump, timing belt, tensioner, rebuild the head also with all new seals. So thats why. But make sure thats your problem.
well if he hasnt seen any problems besides some oil on the spark plugs then i dont think he got too many problems. My suggestion would be what i said. Do an easy compression check on the cylinders. Check your oil cap for white gunk. Figure out the problem first. Then ask around shops and see what they would charge.
theor23
04-17-2014 02:39 PM
