oil in spark plugs??
Old Aug 14, 2006 | 05:22 PM
760_3000GT's Avatar
Default RE: oil in spark plugs??
ORIGINAL: TheEngineer
yea it the labor that will kill you cuz most shops are looking at around 10 hours of work at least.
10 hours to put a head gasket on?? why so much?? what do you you actually have to do tu put it on?? never done it so, just wanting to know, my friend its not going to be happy
Old Aug 15, 2006 | 09:26 AM
well first of all i would make sure thats the problem. Do a compression check and see if any are bad. But the reason its such a long job is because to do it you have to remove the head right off. Then while you have it off there is stuff they will replace (which you should anyway) like the waterpump, timing belt, tensioner, rebuild the head also with all new seals. So thats why. But make sure thats your problem.
Old Aug 15, 2006 | 12:46 PM
RCJr9186's Avatar
all true, but this is actually a minimum. this is all assuming that you haven't hurt anything in the process of blowing the head gasket there are all sorts of problems you can cause but doing this... most comonly is warping the head if you are overheating, i'm not really sure about the others. really not trying to scare you here lol just warning you. for the price of replacing a head gasket at a shop, you could sell your engine ( you won't get much for it but it's better than nothing ) and put it towards a new engine off of ebay or something. i think they sell remanufactured ones for like 1100. keep us posted
Old Aug 15, 2006 | 01:01 PM
well if he hasnt seen any problems besides some oil on the spark plugs then i dont think he got too many problems. My suggestion would be what i said. Do an easy compression check on the cylinders. Check your oil cap for white gunk. Figure out the problem first. Then ask around shops and see what they would charge.
Old Aug 15, 2006 | 05:34 PM
760_3000GT's Avatar
well a mechanic its gonna come to my home to put the new engine in my 3000GT, so I'll try to get my friend here when the mechanic comes so he can check it out
theor23
Apr 17, 2014 02:39 PM
bassplar
Feb 16, 2014 12:52 PM
mitzubshi1
Apr 22, 2012 07:44 PM
JimmyB
Nov 30, 2005 07:03 PM
m168s
Jun 27, 2005 12:47 PM
