ok so i got my turbo on
Old Jan 20, 2007 | 03:55 PM
Simss's Avatar
Default ok so i got my turbo on
ok so I just finished installing my 16g, i dont have any leaks as for oil or coolant. but im still letting off quite a bit of smoke, anything i should be worrying about or is it more likly to be burning all the oil my old turbo had in the piping?
Old Jan 20, 2007 | 04:07 PM
Default RE: ok so i got my turbo on
what color smoke... how much boost? do you have a wideband? what is the AFR
Old Jan 20, 2007 | 04:19 PM
Simss's Avatar
white smoke and its boosting at 15psi and no wideband yet
but after i took it for another drive its doesnt seem to be smoking
also i had a boost controller hooked up to my old t25 but i didn't hook it up to the 16g because i wasnt sure how to
Old Jan 20, 2007 | 09:11 PM
well white smoke is coolant
Old Jan 20, 2007 | 10:56 PM
Simss's Avatar
oh ok... hmm so what do you think is happening? it only craps out white smoke when i floor the car at around 4 1/2 grand and it only does it some of time
Old Jan 21, 2007 | 12:39 PM
well are you sure there isnt a bluish tint to it
Old Jan 21, 2007 | 01:30 PM
ORIGINAL: TheEngineer
your retarded.... I doubt he is buring coolant... it is just running rich which ironically is white as well. grey or black is oil.
remember john all the smoke my car was blowing when it was overboosting. it was going so rich the car wouldnt move that was pure white smoke
Old Jan 21, 2007 | 02:22 PM
EMonz what is the matter with you? I always thought rich = black puff.
Simss didnt you post a thread before about this? If i remember correctly you said you heard a pop? Headgasket if you ask me.
Old Jan 21, 2007 | 03:00 PM
93eclipsegsx's Avatar
ORIGINAL: EMonz57
YOUR RETARTED!!!!.... I doubt he is buring coolant... it is just running rich which ironically is white as well. grey or black is oil.
mike your so mean.
Old Jan 21, 2007 | 03:16 PM
ORIGINAL: Sebba
no..turbos will smoke a greyish color under WOT. Black is oil rich is white. coolant is white. Ever see a turbo car on cold start blow black? its always white and if you have a wideband your AFR at idle reads something like 10.1 and slowly leans out to around 14.8 after it warms up. is there any coolant or other fluids all over the engine bay? is your coolant level getting lower? check your fluids if you have normal amount of coolant then he is fine. His car wont run very long on a bad HG so I still dont think it is that
