to OLDMANSGS
Old Jan 21, 2004 | 09:43 PM
alvar's Avatar
Default to OLDMANSGS
<TABLE cellSpacing=0 cellPadding=0 width="100%">
<T>
<TR>
<TD class=smText width="96%">Posted: Jan/20/2004 at 8:18pm | IP Logged </TD>
<TD align=right width="4%"> </TD></TR>
<TR>
<TD colSpan=2>
<HR>
</TD></TR></T></TABLE>
hi randy, i need your help one more time on my 1.8 engine timin belt.</P>
i set all the pulleys marks up, I put the screwdriverin the hole itwent in about 2 inches, like in the pictures you sent me, but the engine shakes pretty bad, if I rev the engine sounds like poff poff poff,do you think i didn't do it right?</P>
is there any way to know if the timin belt is ok, or could be other thing.</P>
thank you.</P>
Old Jan 22, 2004 | 06:54 PM
oldmansgs's Avatar
<IMG src=smileys/smiley19.gif border="0">Hi alvar, sounds like either you did something wrong or you may have other problems.You may have timing belt off one tooth when you put new one on or some other missed mistake.I would highly suggest that you purchase a compression test gauge and check your compression on all 4 cylinders and verify that they are all about the same.You may have possibly bent a valve when the old belt broke,although i do not think the 1.8 is an interference motor where the pistons can bend some valves when the belt breaks as on the 2.0 liter.Also,verify that you have the spark plug wires on the correct way,and to the correct cylinder. Good luck, hope this helps and you find the problem.
Old Jan 22, 2004 | 10:00 PM
alvar's Avatar
ok Randy, Im gonna check the compression on the cylinders and</P>
the others things, thanks again.</P>
