p/s , and a/c belt
easy 30min fix belt is going to run $20. Loosen up the tentioner pully bolt If I remeber correctly I used a 12mm socket. Back it off as much as you can my need a lil lube (PB Blast or WD40) put the belt around the crank 1st. Its easier to replace the belt with the front passenger side tire off, but you do not have to.
mirrormirageman
04-04-2015 04:40 AM
marx88
06-30-2011 03:54 PM
