p/s , and a/c belt
Old Aug 14, 2008 | 06:27 PM
hettbaby's Avatar
Default p/s , and a/c belt
hey, I have a 96 non turbo and the p/s and a/c belt broke, i was wondering how to repiar it and how hard it is, if anybody can help i would reallt apreciate it. thanx.
Old Aug 15, 2008 | 06:16 AM
Default RE: p/s , and a/c belt
go to any parts store and pick up a haynes manual. It will be the best $20 you ever spent
Old Aug 16, 2008 | 08:20 AM
PappiDread6's Avatar
easy 30min fix belt is going to run $20. Loosen up the tentioner pully bolt If I remeber correctly I used a 12mm socket. Back it off as much as you can my need a lil lube (PB Blast or WD40) put the belt around the crank 1st. Its easier to replace the belt with the front passenger side tire off, but you do not have to.
mirrormirageman
Apr 4, 2015 04:40 AM
marx88
Jun 30, 2011 03:54 PM
agallardo
Oct 29, 2006 11:33 AM
