PLEASE HELP!!!
Old Aug 9, 2008 | 07:38 PM
Zfred10's Avatar
Default PLEASE HELP!!!
Ok so I took out my stereo today to hook up the wires for my boost gauge to the wiring harness. Now my headunit will not turn on. I know I have power because when my faceplate is off, a red light blinks. Why will my headunit not turn on? And for hooking up my boost gauge, the yellow in the wiring harness can be used for a constant 12V? And the Red for the 12V ignition.
Old Aug 9, 2008 | 07:40 PM
Zfred10's Avatar
Default RE: PLEASE HELP!!!
Actually now when I turn the key to accessory, nothing works at all. Meaning my dome lights, inside door lights, nothing in my cluster lights up, and the stereo doesn't even blink red anymore. What is the problem?
Old Aug 9, 2008 | 08:27 PM
dsm1990gsx's Avatar
Did you check the fuses?
Old Aug 9, 2008 | 08:38 PM
Zfred10's Avatar
Checked all the ones I thought I was suppose to check. Do you know which ones in particular to check and where.
Old Aug 9, 2008 | 08:46 PM
dsm1990gsx's Avatar
Check all of them (fuse box in the car)
Old Aug 9, 2008 | 09:17 PM
Zfred10's Avatar
They are all good. Any other suggestions.
Old Aug 9, 2008 | 09:19 PM
dsm1990gsx's Avatar
Did you double check all the work you just did b/c you must have disturbed something.
Old Aug 9, 2008 | 09:40 PM
Zfred10's Avatar
The only thing that I did was splice in a a wire to the yellow wire on the wire harness and then spliced the red wire on the wire harness. I even took them out and put it back to the original way and it still doesn't work.
LeoGS
Nov 6, 2020 06:12 AM
enzo_hashmat2006
Oct 10, 2017 05:46 PM
westentertainer
Nov 8, 2014 12:47 PM
lgibson
Mar 12, 2009 07:04 PM
96eclipsedohc
Feb 8, 2007 09:20 PM
