pop pop no power....
ok i was coming up the road whch is a hill, i was in 3rd at 30mph. I down shifted to second and floored into the turn at around 20mph, i chirpped the tires and started accelerating hard then my exhaust went POP POP and i had no power, i shifted into 3rd and was fine at 15psi. I did a 0-60 last night and didnt run into a fuel cut or anything, WTF happend today?
RE: pop pop no power....
Missfire... the pop pop was igniting fuel in the exhaust... check your plugs and wires
ORIGINAL: Sebba Missfire... the pop pop was igniting fuel in the exhaust... check your plugs and wires |
yea but if this is the only time that has happened.... then thats a little odd doncha thing?
ORIGINAL: Sebba yea but if this is the only time that has happened.... then thats a little odd doncha thing? |
well its a rainy day and its like 70-75 degrees outside
it doesnt have to be cold out for it to happen, thats just one circumstance where it does happen. But it depends on how your engine is running. For some reason the car reached the maximum the ECU will allow the fuel pump or injectors to push and automatically cuts it off to prevent any damage.
ok so what is the cure cause im gettin it bad
are the only mods you have listed on ur sig?
i never ran into this problem on my 97 gst and i ran it pretty hard sometimes...does this happen on all dsm's
