pop pop no power....
Old Sep 3, 2006 | 07:41 PM
paintballproam's Avatar
Default pop pop no power....
ok i was coming up the road whch is a hill, i was in 3rd at 30mph. I down shifted to second and floored into the turn at around 20mph, i chirpped the tires and started accelerating hard then my exhaust went POP POP and i had no power, i shifted into 3rd and was fine at 15psi. I did a 0-60 last night and didnt run into a fuel cut or anything, WTF happend today?
Old Sep 3, 2006 | 08:29 PM
Default RE: pop pop no power....
Missfire... the pop pop was igniting fuel in the exhaust... check your plugs and wires
Old Sep 3, 2006 | 08:37 PM
ORIGINAL: Sebba
not true, that is fuel cut. the pop was def a backfire mine always backfires when I hit fuel cut. depending on weather and temps fuel cut can happen more or less. I fuel cut a 20PSI in 3rd if its colda night if it is a nice day I can run 20 all day
Old Sep 3, 2006 | 08:57 PM
yea but if this is the only time that has happened.... then thats a little odd doncha thing?
Old Sep 3, 2006 | 09:33 PM
ORIGINAL: Sebba
not really. I fuel cut at odd times in my car. like for example the other day I floored it in 5th i hit half boost I was at like 3500 rpms and I hit fuel cut out of no where
Old Sep 4, 2006 | 12:04 AM
well its a rainy day and its like 70-75 degrees outside
Old Sep 4, 2006 | 12:17 PM
it doesnt have to be cold out for it to happen, thats just one circumstance where it does happen. But it depends on how your engine is running. For some reason the car reached the maximum the ECU will allow the fuel pump or injectors to push and automatically cuts it off to prevent any damage.
Old May 21, 2007 | 09:54 PM
spyder4g63t's Avatar
ok so what is the cure cause im gettin it bad
Old May 22, 2007 | 12:00 PM
RCJr9186's Avatar
are the only mods you have listed on ur sig?
Old May 22, 2007 | 12:05 PM
brknhrtdpimp1489's Avatar
i never ran into this problem on my 97 gst and i ran it pretty hard sometimes...does this happen on all dsm's
