pop pop no power....
Old May 22, 2007 | 12:31 PM
50ul }{4ck3r's Avatar
Default RE: pop pop no power....
does not happen on mine at all
Old May 22, 2007 | 12:39 PM
RCJr9186's Avatar
it is POSSIBLE to happen to any car but it all depends on the setup you run... usually happens when you have a turbo that is pushing to much for the fuel system.
Old May 22, 2007 | 01:02 PM
brknhrtdpimp1489's Avatar
gotcha...basically if you upgrade a turbo and dont upgrade a fuel system then you'll go over the max capacity of the fuel system and the ecu cuts power to it so it wont screw up the injectors and burn up the fuel pump...right??
Old May 22, 2007 | 02:02 PM
Well did you get a jerk? Unable to get above a certain RPM? A lot of things can effect that. The quality of gas you got... even though you might have filled up with decent gas... thats no telling what you actually got.
2) Temerature has a lot to do with it. If its hot outside it can make fuel cut come in earlier. There are just so many factors.
Almost sounds like a boost leak or something?
Old May 22, 2007 | 02:12 PM
RCJr9186's Avatar
when i first heard it it sounded like he blew a coupler but if he didn't change anything and is boosting just as much as before than it can't be a blown coupler or he'd still be lacking power. again, are the only mods done to the car in ur sig?
Old May 22, 2007 | 02:15 PM
Dusty Eclipse's Avatar
Having looked at this again... and hearing Rons theory... Im backing it. It sounds like a cracked/blown coupler somewhere... check all your v tubes and whatnot.
Old May 22, 2007 | 02:17 PM
RCJr9186's Avatar
well like i said that's what it sounded like before BUT if he didn't change anything (by that i mean repair or change out his coupler) than he would still be losing boost and since he's pulling just as hard now as he was before..... that can't be it. so it was either fuel cut or knock. you ARE running premium fuel right?
ricckma
Jan 22, 2009 02:02 AM
twarrior
Oct 19, 2008 05:36 PM
dandeering
Nov 23, 2007 05:35 PM
BoostNightRanger
1st Generation
Feb 26, 2007 05:48 PM
spyder4g63t
Oct 18, 2006 08:20 PM
