Porting out Evo III
Old Dec 26, 2007 | 11:27 PM
dorian7's Avatar
Default Porting out Evo III
OK Guys I just gont done doing all the "rough" porting, i am going to clean it up a bit tomorrow, I got the 32mm wastegate out to install the 34. I ported the incoming exhaust out a bunch and just smootherd out the turbine hole, and the wastegate, I also opened up the wastegate hole.
I was also wondering on the incoming exhaust part, does the "rim" actually do anything or should I make it flush with the rest?
[IMG]local://upfiles/13053/A6699FAD3E954C0FB5ACB78EA2537108.jpg[/IMG]
[IMG]local://upfiles/13053/1FCFFAEEB5EE4D628D956E4A0AF455A1.jpg[/IMG]
[IMG]local://upfiles/13053/2D3B111537614E0497DC17AD042DCCAD.jpg[/IMG]
Old Dec 26, 2007 | 11:36 PM
_Adrian_'s Avatar
Default RE: Porting out Evo III
not bad
Old Dec 26, 2007 | 11:39 PM
You have barely started!! Keep going.
Remove that rim too!
Old Dec 26, 2007 | 11:40 PM
dorian7's Avatar
OK so the rim doesn't actaully do anything? Nothing sets on it or anything?
Old Dec 27, 2007 | 02:11 AM
Nope
Old Dec 27, 2007 | 11:58 AM
dorian7's Avatar
OK, I understand that a ring gasket sits there? DOes that help align it or something?
Old Dec 27, 2007 | 12:48 PM
sk8dudety's Avatar
well put the ring gasket on there and check, if not then get rid of it! lol
Old Dec 27, 2007 | 01:17 PM
dorian7's Avatar
I would but the problem is the gasket is still installed in the car
Old Dec 27, 2007 | 03:46 PM
dorian7's Avatar
It just seems like it would be better to keep the step if the ring gasket aligns it.
Old Dec 27, 2007 | 04:28 PM
sk8dudety's Avatar
isnt it usually a good idea to replace gaskets after you've unbolted whatever it seals? could always get a new one and just test fit it
