power window
Old Jun 16, 2007 | 02:16 PM
GANGSTAH33's Avatar
Default power window
i have a ques my driver window doesnt work from the master switch but my passenger does besides the relay does it or does it now have a circuit breaker and if where is it located what might be some of the problems to look out for i checked all the wires none of them are damaged
Old Jun 16, 2007 | 02:57 PM
I Drive Naked's Avatar
Default RE: power window
Check for continuity at the switch, and if you have power/ground, then pull off your door panel and check for power and ground at the window motor.
Unplug the motor then plug in the switch.
with your test light touching the contacts, operate the switch, if no power to the window motor, you have a bad switch.
But if you're getting power to the motor, then you looking at a bad window motor.
Old Jun 16, 2007 | 03:40 PM
Dusty Eclipse's Avatar
Its more than likely the motor... assuming I understood that...
Old Jun 16, 2007 | 11:23 PM
GANGSTAH33's Avatar
well i already did all that check for continuity at the switch i even had a spair switch and window motor did not work and due to the wiring diagram it says it has a circuit breaker but i cant find it now im new to this electrical im trying to master it but when i probe the power window control module the white wire with a self powered test light then the window goes up and down and the test light lights up
3000gt1999
Jan 11, 2007 09:12 PM
ajav05
Aug 23, 2006 08:21 PM
desi_dude
Aug 10, 2006 09:30 PM
tgtonway
Mar 28, 2006 02:17 AM
Dookie
Dec 15, 2005 03:59 PM
