problem 97 awd talon
Old Jul 4, 2007 | 08:06 PM
rfritzinger02's Avatar
Default problem 97 awd talon
Real problem here, my car was making a strange noise from the right front side of the car, took it around the block and it was doing it more and more. I tried to put it in first gear from neutral and it wouldnt go in to easily, when i actually got it in, i pulled out and went for a little then just completely stalled in the middle of the road. I couldnt get it to pull out then, and I had to push it home. The car does start, and sounds fine when revved in neutral, but when in first it wouldnt pull out it just kept bucking and stalling out.
Old Jul 4, 2007 | 08:18 PM
sk8dudety's Avatar
Default RE: problem 97 awd talon
sounds like you got a clutch problem my friend...
Old Jul 4, 2007 | 09:05 PM
silvercoupe97's Avatar
Did you check the fluid by chance? It sounds to be more than the clutch, it sounds like the tranny. The clutch is a good place to start though.
Where does the pedal sit when the clutch is disengaged/engaged?
What is this strange noise btw? What was the last thing done to the tranny and how long ago?
Old Jul 5, 2007 | 04:29 AM
50ul }{4ck3r's Avatar
CRANKWALK...like my buddy sebba always says
Old Jul 5, 2007 | 04:53 PM
Like a clicking noise, kinda like baseball card in a bike spoke. Right front side. I think the clutch is the best bet because when I dont have it pushed all the way to the ground even if i am giving it gas it stalls. I dunno if this helps but there is already a stage 2 clutch on it.
Old Jul 5, 2007 | 05:56 PM
i think maybe its the Throw out bearing. That would explain the sounds (maybe) and the car not wanting to shift and having to push all the way to the floor.
Old Jul 5, 2007 | 07:50 PM
Dusty Eclipse's Avatar
Im going with Jon on this one. THrowout bearing
paintballproam
Dec 3, 2006 12:32 PM
illeagle
Sep 2, 2006 08:21 PM
illeagle
May 15, 2006 12:44 AM
BrunoBoy650
1st Generation
Feb 1, 2006 08:41 PM
sho808
Dec 19, 2004 10:50 PM
