Pulling the valve cover 46g3
Old Dec 9, 2006 | 06:24 PM
Simss's Avatar
Default Pulling the valve cover 46g3
Ok so right now im trying to pull the valve cover on my gst so i can paint it.
anyway i took all of the bolts off of the top cover and it's still really tight
and before i start to try and yank it off are there any other bolts anywhere else or anything i should know/do?
Old Dec 9, 2006 | 07:20 PM
paintballproam's Avatar
Default RE: Pulling the valve cover 46g3
Just all of those little 10mm bolts on the top, just use something to pry it off like a putty knife
Old Dec 9, 2006 | 07:24 PM
5Tizzle's Avatar
if you didnt get the ones inside the deeper part of the valve cover, there are like 5 or 6 of them holding it on. Theyre by the spark plug wires
Old Dec 9, 2006 | 07:43 PM
Simss's Avatar
yeah i did all of that, i just decided to leave it on for now though because i cant get a new gasket this weekend...
what sucks though is when i tightening back up i cracked it
so the only thing i think i can do is epoxy it until i can get a replacement
Old Dec 9, 2006 | 07:54 PM
damn, 22 inch pounds per bolt shouldnt crack it. sorry to hear that man
Old Dec 10, 2006 | 02:20 AM
Simss's Avatar
yeah its all good, just went to autozone and got some J.B. weld And so far so good...
Old Dec 10, 2006 | 06:37 AM
silvercoupe97's Avatar
Remember that JB weld takes 24hrs to fully cure. RTV would have done just fine.
One trick to the valve cover is to never torque it down (with a torque wrench that is). It's so easy to crack it with one...I've done it enough to hate my torque wrench, lol. I've gone to using a 3/8" rachet until it's "tight" and watch for leaks, then tighten it down a bit more if it is leaking. In the end, I would rather do that than crack it after taking the time to paint it.
If your valve cover is still stuck, GENTLY tap it with a rubber mallet or put a piece of wood on the sides and GENTLY tap it with a hammer. As long as all the bolts are removed, the gasket/RTV seal should break free after that. I stress gentle...
[IMG]local://upfiles/10268/31780FF79A394B048636870F075BBA58.jpg[/IMG]
Looking at the pic, there are 8 bolts on the outside and 6 on the inside. Make sure all 14 are removed.
dksnj
Nov 13, 2006 01:05 PM
ruserge88
Apr 14, 2006 09:19 AM
cptkid570
Dec 14, 2005 12:59 PM
avshockey
Jul 21, 2005 06:43 PM
carcarnotjarjar
May 2, 2004 01:08 PM
