Putting on a FMIC
Old Oct 27, 2006 | 06:03 PM
agallardo's Avatar
Default Putting on a FMIC
In order to put on a FMIC, you have to remove something infront of your radiator. What line is that called? And if someone can help me out with the "relocation" part, that would be awesome.
Old Oct 27, 2006 | 06:36 PM
Default RE: Putting on a FMIC
its called the power steering cooling line. Its a metal line that loops around in front of the radiator. The easiest way to get around it would be to cut the line and replace it with a rubber hose and clamps.
Old Oct 27, 2006 | 06:48 PM
There are some kits that you dont need to do that.
You may need to change one of your fans to a slim fan .
Old Oct 27, 2006 | 07:40 PM
5Tizzle's Avatar
ORIGINAL: TheEngineer
Well without a power steering cooling line..........wont the fluid get pretty warm and ineffective?
Old Oct 27, 2006 | 07:50 PM
No hes saying you just need to make it flexy... so.. make it a rubber hose so it can go around it
Old Oct 27, 2006 | 08:05 PM
yea but you do take the cooling part out of it in the process. But dont worry there really is no side affects. I had a rubber hose on mine for a while without any problems/changes
Old Oct 27, 2006 | 08:06 PM
5Tizzle's Avatar
could you use something like an oil cooler for the power steering fluid?
Old Oct 27, 2006 | 08:09 PM
im sure you could. You would need a crap load of fluid to fill it though. I say its a pointless expence
Old Oct 27, 2006 | 08:17 PM
5Tizzle's Avatar
if the PS fluid doesnt get cooled...will it damage the system or will it just work slightly worse?
Old Oct 27, 2006 | 08:39 PM
well its only the line that your changing.. and its not like your removing it totally.. your jsut makign it rubber so it can go around it.
