Putting on a FMIC
Old Oct 27, 2006 | 09:15 PM
5Tizzle's Avatar
Default RE: Putting on a FMIC
well rubber cant change temperatures the same as a thin metal pipe can....rubber is made to keep things out or in, so it seems it wouldnt work the same as it usually would.....hmmmmmmmmmmmmmmmmmmm
Old Oct 27, 2006 | 09:18 PM
well it will still operate jsut fine
Old Oct 27, 2006 | 09:20 PM
your fine. Like i said its not gonna change the reliability of it or the performance
Old Oct 27, 2006 | 09:27 PM
5Tizzle's Avatar
alrighty.....sounds good
Old Oct 28, 2006 | 12:02 AM
agallardo's Avatar
Let me get this straight. Cut my power steering line, replace with a rubber hose and clamps. But first empty out the fluid. Then reconnect and add fluid after mounting the FMIC? Is this right?
Old Oct 28, 2006 | 12:04 AM
yes
Old Oct 29, 2006 | 04:58 AM
TX97GST's Avatar
The shop I had put mine it just moved the line behind the metal bracket. And I have the Blow through SBR IC.
Old Oct 29, 2006 | 11:35 AM
agallardo's Avatar
What do you mean moved the line behind the "metal bracket?"
Silvertooth
Jun 19, 2007 10:56 PM
bling bling
Oct 16, 2005 09:13 PM
reanimtdcowboy
11
Oct 5, 2005 09:44 PM
matt02708
May 31, 2005 01:37 AM
DSMDUDE
Mar 30, 2005 09:59 PM
