questin
Old 12-23-2005, 04:11 PM
georgegsx's Avatar
Default RE: questin
where can i get a gm mas t
Old 12-23-2005, 04:57 PM
DSMTalonAWD51's Avatar
Default RE: questin
you dont need any of that until you run more than 16psi. keep the boost down and you are fine on a stock setup
Old 12-23-2005, 05:15 PM
Default RE: questin
yeah but what is the point of having the stuff to boost with if your not going to try it out. but he is right if you are just wanting a more reliable turbo but plan on keep boost down under 16 psi then you will be fine but over 16 psi stock fuel won't keep up.
Old 12-23-2005, 11:19 PM
Default RE: questin
he already bought the turbo, he just wanted to know if he needed to buy anything else, and the answer is no, not unless he wants to increase the boost. Even so, a T28 at 12psi will be quicker than a T25 at 16psi so its still a good upgrade in itself
xeclipsex99
05-25-2006 11:46 AM
Quick Reply: questin
