question about key less entry
Old Mar 9, 2008 | 07:08 PM
saxonp4's Avatar
Default question about key less entry
i have a 98 eclipse gs, with the factory keyless entry. my lock/unlock button works fine on the remote, but my hatch release button does not work at all, along with my panic button. if i press and hold my lock/unlock then my alarm will sound. but what can be done to allow the rear hatch to work from the keyless remote?
Old Mar 9, 2008 | 07:12 PM
tjbiker031's Avatar
Default RE: question about key less entry
do you have the stock remote or aftermarket, cuz far as i know the factory remote doesnt have a hatch button.
Old Mar 9, 2008 | 07:16 PM
saxonp4's Avatar
well, i bought the car used and it came with the same remote that i have today. so it may be aftermarket. if it is, and the stock ones dont have the button, then thatll explain why. but is there any way to activate the rear hatch for remote entry
darknigh7th's Avatar
well at least your doors unlock, the one I have, it unlocks my passenger side door but that door handle is broken off, it tries to pop my drivers side, but it doesn't.
Old Mar 9, 2008 | 07:17 PM
saxonp4's Avatar
lol, yeah i guess i am thinkful for that. mine work perfect!
Old Mar 9, 2008 | 08:00 PM
well i just yell ****ing dsm... i'm just waiting for my drivers side to break off and i'll start climbinb in through the hatch.
Old Mar 9, 2008 | 08:04 PM
shreff99's Avatar
Someone probably lost the "original" key f.o.b. (proper term for "remote") and programmed that one...The one you have is not the original f.o.b...There is no hatch button on the original ones..There is a lever on the driver's side floor and also the key lock on the back of the hatch are the only ways to unlock that hatch...There is no power lock motor in the hatch so there is no way to activate that button so it's there for decoration LOL....To reprogram your key f.o.b., put the key in the ignition and without turning the car on, cycle it back and forth from the "off" position to the "on" position about 8 times and then press the "lock" button on the f.o.b...You should hear the locks move or lock and unlock and that's how you know it's programmed...Try that.
Old Mar 9, 2008 | 08:20 PM
yeah it's really easy, mine works.. halfway lol.
Old Mar 9, 2008 | 09:02 PM
saxonp4's Avatar
yeah, that worked, but it took some trial and error, you have to do it really quick. but if worked, thanks a lot!
Old Mar 10, 2008 | 11:09 AM
shreff99's Avatar
Glad to be a help.
paintballproam
Feb 8, 2012 03:33 PM
joetiii
Jun 24, 2011 06:04 PM
casr
Jul 16, 2010 11:52 PM
Wyte
Jul 27, 2007 04:40 AM
SL3000gtTT
Jun 24, 2006 12:29 PM
