ran...... then crank but no start
<IMG src=smileys/smiley5.gif border="0">my 1997 rs worked fine for a few errands.....then I stopped and it would not start. I checked the spark...in fact changed the plugs...good spark. While I had #1 out I visually saw that gas was being injected. I'M perplexed....I have fuel and fire but the car wont start. Anyone else have a simular experience? What were the steps of your solution?
Hi. i just had the same problem. My car runs great. i went to a friends house last night and when i tried to leave. nothing.. jsut sits there and cranks.. did you get yours running. what did you do.. my car is stuck about 50 miles from my house and i need to get it at least to my house. you can email me at my home address if you can. </P>
</P>
Thank You</P>
Terry</P>
brownt22@comcast.net</P>
<FONT face="Arial, Helvetica, sans-serif" size=3>i am having the same problem with my 99 eclipse, RS. it's very tempermental, it starts when it wants to, sometimes it will not. i checked the same things that Tom97rs checked, same result. have taken it in to get checked out and they cannot find the problem.</FONT></P>
I went to tow my car today and it started. so i tried to drive it. i made it about 5 miles then the check engine light came on and it died. and now wont start again. so i dont have a clue what it is. I am planning on taking it to the shop tomorrow. I can only imagine the bill.</P>
</P>
</P>
Terry</P>
<FONT size=2>i'm taking my car into the shop tomorrow also. of course it is running fine now, over the weekend it was horrible, had to try at least 3 times everytime i needed it to start. it turns over, but the engine won't start. let me know what you find out and i will do the same. good luck!</FONT></P>
<FONT size=2></FONT></P>
<FONT size=2>Natalie</FONT></P>
The problem was the cold air sensor. The way to start is drain oil...remove plugs...let excess fuel evaporate...I left overnite. New plugs in morning and oil change. Then to Mitsubishi. The error message indicated the cold aair sensor. The way it was explained was that the computer in car was receiving a signal that it was sub-zero. Dumping fuel and flooding. Was about a $200 repair. Not covered under drivetrain warranty.<IMG src=smileys/smiley19.gif border="0">
I have a 88 supra that went in for a cracked head gasket. ran fine ,as it could with a blown HG, before it went in..they replaced the HG put it back together..and no start..cranked fine, like it was just out of gas. $400 bucks, 1 ecu, a new set of plugs/wires, and countless bruised knuckles later...I found out it was out of time..180 out.</P>
Good luck</P>
<FONT size=2>well i got my car back from the mechanic and my problem was that the valve cover gasket was cracked, and was leaking into the spark plug holes, which was causing the problem of the car cranking away, but notbeing ableto start. they replaced the gasket and grommets and it's running awesome, and no more trouble starting. only cost $124 to fix, not bad. </FONT>
Mine did the exact thing but all that was wrong was a wire that went to the starter solinod under the dash came loose. I just rewired it back together. Try to check your starter and see if its getting power and if its not clicking or kicking overthan it is bad. If it isnt getting power take the panel off thats on the side fo the center console passenger side of the car located where the radio is and everthing and there will be like two black boxes check and see if its getting power if it is and its not clicking when you try to start it than that is your problem. It costed me 65 bucks to fix.</P>
they charged you 124 bucks to change the valve cover gasket and plug seals<IMG src=smileys/smiley3.gif border="0">.</P>
Holy over priced mechanics job batman..thats was way too expensive. It takes like 20 minutes to change those seals out. Next time if they tell you what it is and its just a seal replacement, especially on top of the engine liek that, take it home and do it yourself..CHilton's works wonder...I promise <IMG src=smileys/smiley20.gif border="0"></P>
</P>
gormleyp
Feb 5, 2015 03:34 AM
