Strange engine noise on cold start and then when changing gear, then it goes away !
Old Feb 4, 2015 | 08:34 AM
gormleyp's Avatar
Default Strange engine noise on cold start and then when changing gear, then it goes away !
Hello there
I have a 2011 Mitsubishi Outlander GX4 2.2 DI-D, 6-speed manual transmission, 45k miles on the clock.
It has recently developed a strange whirring noise from the engine which (after 2 weeks of investigation) my local Mitsubishi dealer cannot identify with any certainty.
The noise is apparent when the vehicle is started from cold.
If I were to let the car sit there running, the noise will eventually go away after about 5 mins.
But if I were to start driving, the whirring noise becomes quite loud when I change gear ... in other words, at the point when I have pressed the clutch and taken my foot off the accelerator. And then as mentioned above, the noise goes away after 5 mins driving.
If any one has any ideas or advise, I would be very grateful.
Cheers
Old Feb 4, 2015 | 10:32 AM
Akzle's Avatar
the engine which the mitsubishi dealer cannot
identify.
Need to be a bit more descriptive.
Id be looking at fan clutch or other things that move.
Old Feb 4, 2015 | 11:30 AM
2001Mitch3.5XS's Avatar
Haaa, The Stealership is usually pretty good with this. I guess the warranty is up..lol
Old Feb 5, 2015 | 03:34 AM
Deon's Avatar
I had a similar cold start noise on a BMW 3 series a few years ago and after much research found the culprit was the one way clutch on the alternator pulley seized up. Replaced the pulley and problem sorted.
acuz604
Mar 27, 2015 03:28 AM
rexbd
Jan 29, 2008 07:18 PM
soundcolor
Mar 3, 2007 09:36 AM
nyc95gst
Feb 12, 2007 05:11 PM
Drizzo
Feb 18, 2006 01:31 PM
