random miss
Old Sep 28, 2007 | 11:56 AM
anko_kun's Avatar
Default random miss
when my gst is at idle it has just started missing evry randomly some times it dose not outher times it dose do yall have any thoughts on what the problem might be
Old Sep 28, 2007 | 12:19 PM
sk8dudety's Avatar
Default RE: random miss
does it do it under a load? like when you give it gas? if so then i'd say change your plugs and wires... if not and it just does it at idle, i'd say that you'd have a vacuum leak somewhere. trace it, you maybe able to hear a hissing under the engine compartment from that leaking vacuum hose
Old Sep 28, 2007 | 02:28 PM
NGK Plugs (not iridium) and OEM wires : )
Old Sep 28, 2007 | 03:28 PM
anko_kun's Avatar
its not the plugs or wires there both only a month old ill check for the vacume leak'
Old Sep 28, 2007 | 03:32 PM
I wouldnt say that. What did you replace them with?
Old Sep 28, 2007 | 03:35 PM
anko_kun's Avatar
taylor 10.4 mm race wires with ngk 1step colder plugs
Old Sep 28, 2007 | 03:39 PM
Those plugs gaped right?
The wires more than likely suck..regardless what you paid for them.
Old Sep 28, 2007 | 03:50 PM
anko_kun's Avatar
the wries dont suck there the same wires that my dad pro gas darg car runs
Old Sep 28, 2007 | 03:52 PM
Okay : )
Then i say you just need to gap em
Old Sep 28, 2007 | 03:55 PM
anko_kun's Avatar
they have the correct gap
