Really Big Problem
Old Feb 28, 2008 | 10:24 AM
saro's Avatar
Default Really Big Problem
Okay people here is the problem that i reallly really need help on.My car is spitting oil out.If i go over 100mph or rev it up too high.The didpstick comes up and i get oil all over my engine.I have changed the oil and put the proper level in.but it stills does it..The worst feeling in the world is having a turbo engine that you cant do any thing wit..I have an 97 Eagle Talon TSi.any advice i would love!!!!!!!!! I took pics but its alil hard to see the oil..but u can see the dip stick sitting up..this is after talkin to 120 and yes i have full syn. in it....SOME ONE PLEASE HELP!!!!!!
[IMG]local://upfiles/15280/2530E6EA6B1A44358630726E0E6963A3.jpg[/IMG]
[IMG]local://upfiles/15280/07559006C164405AA6DA1B8318EA6C8D.jpg[/IMG]
[IMG]local://upfiles/15280/C1264D86767249D7B7136DB95838FDB3.jpg[/IMG]
Old Feb 28, 2008 | 11:32 AM
Default RE: Really Big Problem
sounds to me like you either need a new dip stick or rubber gasket on it. Since i dont even see the rubber gasket in the dip stick in those pics. But if that doesnt fix your problem then you have an even worse one called blow by, caused by wearing rings. So first try changing out the dip stick with a good one. If it still doesnt stay, maybe attempt to hold it in with something. If that doesnt do the trick then do a compression test on the engine because you may have a bad ring
Old Feb 28, 2008 | 01:44 PM
sk8dudety's Avatar
te what exactly is blow by? im assuming it has something to do with a bad ring that lets either gas or ignited gas past the piston and into the crankshaft and oil pan?
Old Feb 28, 2008 | 02:02 PM
This actually has a good explanation.
http://www.misterfixit.com/blow-by.htm
But basically it would be fuel and air passing though the worn rings and causing excess pressure in the crank case thus it may pop the dip stick out
Old Feb 28, 2008 | 02:32 PM
dsm1990gsx's Avatar
I had the exact same problem in my 93 tsi and it ended up being just the dip stick seal was worn out. I replaced the dipstick and it was fine ever since.
Old Feb 28, 2008 | 10:40 PM
98gstspy's Avatar
same here i think the dipstick cost me like 7 bucks not a big deal. i just wasnt cool to c oil on my driveway. but a simple fix is way better then it being something expensive like i thought it was
Old Feb 29, 2008 | 09:36 PM
TheAdvocate's Avatar
You would get some oil out around the exhaust mani also.. But ya, I had this problem.. New dipstick fixes it..
crghill
Aug 6, 2012 06:39 PM
Gstfat
Apr 30, 2008 10:32 PM
burnmyeyes
Dec 14, 2006 12:08 AM
jerusry
Jul 17, 2005 06:34 AM
98GS_Tspyder
Dec 4, 2004 03:28 PM
