rear sway bar connectors
Old Mar 7, 2007 | 02:37 AM
hondo21's Avatar
Default rear sway bar connectors
My son has a '95Eclipse with a 2.0L non-turbo engine. We've been replacing suspension parts like the struts and bushings and want to replace the rear sway bar links, but can't find them when I search typical parts sites. Ican findthe front ones a lot of places but no one has the ones for the rear. Are they called somethng else? Where can I find them? The dealer wanted $78 each for the rear.
Your site has been great and its helped us do most of the work on his car ourselves!
Thanks!
Old Mar 7, 2007 | 02:51 AM
50ul }{4ck3r's Avatar
Default RE: rear sway bar connectors
I think this is what your looking for...just look on down the page
http://www.roadraceengineering.com/eclsuspension.htm
Old Mar 7, 2007 | 09:29 AM
They are called rear sway bar bushings. Like he showed RRE has them. But couldnt you just get some at any local parts store?
Old Mar 9, 2007 | 12:27 AM
hondo21's Avatar
Thanks guys - I do have a bushing set that I can put on. But the rear sway bar is not attached with one bushing on each side, its a connector with a bolt & bushing on each end.
Here's what they look like, but this says its for a '94. It's the same set up for the front, only longer connectors.
http://cgi.ebay.com/ebaymotors/2-SWA...ayphotohosting
Is it possible we have a '94? Is there identification on the car somewhere to help me fiqure this out?
Old Mar 9, 2007 | 10:55 AM
I still dont see how a local parts store wouldnt have them or at least be able to order them. Both times ive had to buy these for 2 different cars, they had them in stock. They werent factory parts, but they still did the job
Old Mar 9, 2007 | 01:51 PM
estraw's Avatar
ORIGINAL: hondo21
10th didget on the VIN number tells you the year, if its a 95, the 10th didget will be an S. if its a 94, then it will be an R
not to mention the body styles are much different
Maximus99
May 27, 2006 06:02 AM
Maximus99
Feb 22, 2006 01:51 AM
Maximus99
Maximus99
Feb 21, 2006 11:51 PM
gforceauto
Mar 5, 2005 12:27 AM
