Replaced plugs now no spark
Old Dec 23, 2007 | 06:19 PM
nyc95gst's Avatar
Default Replaced plugs now no spark
So I replaced my old plugs and wires with oem NGks and Magnecore wires. I am getting no spark now. I mean nothing at all. I gapped them at 28 and I triple checked the wiring order. What the hell?
Old Dec 23, 2007 | 06:47 PM
tjbiker031's Avatar
Default RE: Replaced plugs now no spark
check all the connections, broken wire? loose connection? and did you try to put the old ones back on to see if they worked?
Old Dec 23, 2007 | 08:11 PM
something must be disconnected But BTW the correct gap on the spark plugs should be 0.032. Also what was the part # on the NGK's
Old Dec 23, 2007 | 09:29 PM
nyc95gst's Avatar
Yea I just tossed on the old plugs and wires and still nothing. Is it possible I shorted something. I mean engineer I just disconnected the battery pulled the plug wires and the plugs. And even if my gap is wrong, it should still give me something, right?
WTF?
Old Dec 23, 2007 | 10:17 PM
Grab onto the plug... that will tell you if any juice is going through it.
Old Dec 24, 2007 | 12:04 AM
nyc95gst's Avatar
The plugs are: BPR 7ES
Old Dec 24, 2007 | 04:40 AM
nyc95gst's Avatar
Ok, I got the car to start. I remembered I have constant electrical issues and decided to jump the battery. It worked, but now when I turn on my headlights the car acts like it is about to die for a quick second (lights dim, car bogs down, etc). I guess i'll post this in another thread.
Thanks all.
Old Dec 24, 2007 | 08:44 AM
Check your grounds bud! If all your grounds are good, take the alternator to Autozone and get that bitch tested.
Old Dec 24, 2007 | 11:12 AM
nyc95gst's Avatar
Ok I will, but I know it's not my alt, cause I replaced it last year.
Thanks Sebba, all.
Old Dec 24, 2007 | 11:13 AM
Im betting who ever put it in, didnt secure the ground properly : )
