reservoir bottle boiling
today I parked and turned off my car and heard something sounding like bubbles, i turned off my radio and opened my hood and noticed the reservoir bottle was boiling but the temperature was normal and the car had some water, does anyone have an idea what this can be, has this happend to someone else.
RE: reservoir bottle boiling
how old is the coolant, check it and make sure you have a 50/50 mix on the coolant if you have put water in it or just stright coolant you probably have a incorrect mix of coolant. if its mixed right, then how old is the thermastat?
The thermostat is about 6 months old, I had a heating problem a few months back and practically replaced everything that has to do with cooling. I noticed that the radiator cap gaskets are starting to peel, can this be the problem.
I agree with 94 mitsu. Check the compression, and also pull off your oil filler cap look at the bottom of it an see if it looks like there is any coolent mixed in your oil. I had the same boiling coolant problem and it turned out to be a blown head gasket. i was a young dsm boost junkie, running 17.5 lbs on stock turbo stock fuel not smart.
geegee
07-10-2006 06:46 PM
