reservoir bottle boiling
Old Jan 14, 2005 | 03:35 AM
MORRISSEY's Avatar
Default reservoir bottle boiling
today I parked and turned off my car and heard something sounding like bubbles, i turned off my radio and opened my hood and noticed the reservoir bottle was boiling but the temperature was normal and the car had some water, does anyone have an idea what this can be, has this happend to someone else.
Old Jan 14, 2005 | 03:20 PM
1398spdr's Avatar
Default RE: reservoir bottle boiling
happened to me once, never heard it again, so i dont know, sorry i cant help ya....
Old Jan 16, 2005 | 04:02 PM
vertstanggt's Avatar
Might have a clog somewhere so all of the coolant can't circulate. Maybe in the radiator itself. If it keeps up try flushing the coolant system.
Old Jan 17, 2005 | 03:36 PM
96awd's Avatar
how old is the coolant, check it and make sure you have a 50/50 mix on the coolant if you have put water in it or just stright coolant you probably have a incorrect mix of coolant. if its mixed right, then how old is the thermastat?
Old Jan 17, 2005 | 03:50 PM
MORRISSEY's Avatar
The thermostat is about 6 months old, I had a heating problem a few months back and practically replaced everything that has to do with cooling. I noticed that the radiator cap gaskets are starting to peel, can this be the problem.
Old Jan 17, 2005 | 08:28 PM
1398spdr's Avatar
could be, if your getting air into the cooling system then the coolant wont remain pressurized and will start to boil......
Old Jan 17, 2005 | 08:54 PM
96awd's Avatar
yea i would change the cap, then burp the system to make sure you have all the air out of it.
Old Jan 18, 2005 | 12:31 PM
94 Mitsu Eclipse's Avatar
if that doesn't fix it, then i would do a compression check. there might be a head/gasket problem and it's letting exhaust gases to go into the coolant. I have a pickup that did that.
Old Jan 20, 2005 | 03:40 PM
Yea, def bleed the system, run it with the cap off and sqeeze the hoses and whatnot and add fluid as needed, might just be air.
Old Jan 23, 2005 | 11:29 PM
DSMTalonAWD51's Avatar
I agree with 94 mitsu. Check the compression, and also pull off your oil filler cap look at the bottom of it an see if it looks like there is any coolent mixed in your oil. I had the same boiling coolant problem and it turned out to be a blown head gasket. i was a young dsm boost junkie, running 17.5 lbs on stock turbo stock fuel not smart.
SpyderGrl85
Feb 15, 2008 10:58 AM
jump_the_clutch
Feb 7, 2008 06:38 PM
Gerry55
Aug 26, 2007 08:42 PM
geegee
Jul 10, 2006 06:46 PM
roscoe
Jun 25, 2006 08:31 PM
