Rev Limiter
Old Sep 2, 2006 | 06:51 PM
gstTurbo2011's Avatar
Default Rev Limiter
is there a way to take off my rev limiter without buy an exspensive ecu chip or anything like that..? i have 98 gst
Old Sep 2, 2006 | 07:56 PM
Default RE: Rev Limiter
what for? you need a built motor to handle it (mainly build head) and ya you would need a reflash is avail for that car and or a standalone will do the trick, im sure there may be a piggy back too but your looking at some $$$ either way
Old Sep 2, 2006 | 09:26 PM
Can i ask why you would want to?
Old Sep 2, 2006 | 11:29 PM
don't like restrictions
Old Sep 2, 2006 | 11:41 PM
ORIGINAL: gstTurbo2011
do you like dropping valves and blowing motors then??
Old Sep 3, 2006 | 01:33 AM
ha i got ya
Old Sep 3, 2006 | 03:48 AM
ha i got ya
a rev limiter is not a restriction it is a fail safe so you dont kill your car in 2 minutes. even cars with built motors and heads have rev limiters depending on displacement the higher it is set usually the lower displacement the higher the rev can be. I see stock EVOs do a 7800 limiter but built 2.0L average around 9k and 2.3L strockers do 8k-8.5k
Old Sep 3, 2006 | 06:11 AM
Darkspeed's Avatar
you should be more worried about a speed governor. err do eclipses have speed governors?
Cause i used to have a 1994 Mazda MX-6 and from personal tales, that thing did NOT have a speed governor so yea. Does the eclipse have one?
1992blueeclipse
1st Generation
Apr 15, 2012 01:48 PM
wackdaddy69
Feb 28, 2008 06:03 AM
flying_gs
Aug 15, 2007 06:18 PM
Brockley
Aug 14, 2007 09:09 PM
slayeroger
Mar 16, 2007 08:23 PM
