reverse gear problem
Old Apr 26, 2006 | 01:09 AM
inw_j's Avatar
Default reverse gear problem
hi, i have a problem with my 1997 gsx, whenever i try to shift into reverse gear, the gear seems to stuck in neutral gear, what plemlem could it be?thank you.
Old Apr 26, 2006 | 01:35 AM
DSMTalonAWD51's Avatar
Default RE: reverse gear problem
dsm trannys suck, that could be the problem my reverse sometimes has a grinding problem, but i found that as long as you have the clutch pushed al the way to the floor, and if shift into either 1st or second before going into reverse, it doesnt grind, so maybe it will help you
Old Apr 26, 2006 | 02:59 AM
5Tizzle's Avatar
ORIGINAL: DSMTalonAWD51
And if that doesnt work, let go of the clutch a tiny bit while in 1st or second just to budge the car a little bit, then it will most likely go into reverse.
Old Apr 26, 2006 | 10:30 AM
well i dont want to assume anything....so first off...is the car a manual or an automatic. Cuz that will make a big difference.
bnrsmith
Aug 5, 2019 06:09 PM
rossg
Feb 8, 2008 09:07 PM
bradshaw
Jan 30, 2006 12:20 AM
grn97GS
Sep 27, 2005 12:57 AM
grn97GS
Sep 23, 2005 05:37 AM
