Reverse Lights Don't Work
Old Jan 23, 2006 | 05:13 PM
MJANGEL28's Avatar
Default Reverse Lights Don't Work
Hey, well my boyfriend has a '99 5-speed and for some reason his reverse lights doesn't work went put into reverse. It only works once in a great while. The bulbs and fuse is okay. So what else could it be?
Old Jan 24, 2006 | 04:27 PM
estraw's Avatar
Default RE: Reverse Lights Don't Work
theres something called a tranny sensor that should be right on top of transaxle. you'll need to take out the battery and battery shelf to get to it. once that's done, look on the top of the tranny towards the back driver's side and you should see a wire sticking out, that should connect to the back-up light switch
Old Jan 24, 2006 | 04:36 PM
got the same answer in both sections this is here and in the tech section
evrchanging-ecl
Jan 16, 2014 01:36 AM
justyn01
13
Jul 10, 2011 05:34 PM
Electech1
Oct 20, 2006 04:20 AM
Electech1
Sep 14, 2006 06:41 PM
MJANGEL28
Jan 24, 2006 11:30 PM
