Short Shifter Question
Old Oct 3, 2005 | 03:37 AM
naka's Avatar
Default Short Shifter Question
hey was up. Im driving a 98 gst and i was looking for a short shifter. now...i dont kno much about em so i was gonna buy one off of ebay. BUT, i thought i should get some help from you guys who prob know more about short shifters than i do. so do you have ideas for which one i should get? And also...is it worth getting one? does it make a dramatic change? thanks a lot for the info!
Old Oct 3, 2005 | 10:42 AM
slow420a's Avatar
Default RE: Short Shifter Question
ORIGINAL: naka
Orginally I got a pacesetter from ptuning.com for 80 bucks or so. It was a improvment from the stock on with shorter throws and it was 2 inches shorter then the stock shifter but It has a bit of play b/c a screw dictates the stiffness of the throws. After a bit It would come lose. So I threw 2 lock nuts on the screw on the shaft with some red locktight. After a while I was bord with it and took my stock shifter and chopped it down to 3 inches long. That was super short , but the throws were still long. I was happy with that untill I snapped it in half banging 4th gear. Then I chopped the pacesetter to 1 1/2 inches and I am currenely using that. Its nasty short with short throws, I wouldent trade it for the world. The reason the stocker shifter snaps when you chop it and weld it is because its a hollow tube where the pacesetter is solid steel. Match that shifter up with a weighted shift ****, some sihfter bushings from machv.com, and a ss cluch cable line and my car now feels like a real sports car.
Old Oct 3, 2005 | 07:53 PM
DSMTalonAWD51's Avatar
any time you decrease the shifter throw, you are going to increase shift effort. if you want it for racing and fast shifting, it wont be worth it because it wont help much at all. its actually easier to shift with a stock shifter. If you want a shifter for a sportier feel, then id reccomend the B &M short shifter, its the only quality piece out there for 2gs.
No matter what you decide, you should get polyurthane shifter mount bushings. Theyre about $10 and will make you shifter feel rock solid, a much bigger improvement than getting a new shifter.
Old Oct 3, 2005 | 09:45 PM
TheAdvocate's Avatar
Im driving one right now with a short shifter in it and its fun as hell... But I could go through the gears a lot easier with the stock one... Mayb its because I havnt had the short shifter very long and im not use to it..
Old Oct 3, 2005 | 11:40 PM
slow420a's Avatar
ORIGINAL: DSMTalonAWD51
I agree that the gears are easier to get into but since I have had my short throw I can bang gears with out grinding... example, keep foot all the way down on the gas, tap cluch pedal to release the gear lock and throw it into gear. At first it thought it was really bad for the tranny but I changed the tranny fluid two weeks ago (first time changing the oil since I ahd the car, about a year) about 3 little metal flakes came out, and that was about it.
Deff go fo the shifter bushings, I highly reccomend them, once I got my short thow they riped to pices.
Old Oct 5, 2005 | 10:16 PM
badass91hatch's Avatar
i am interested in getting a b&m for my 98 spyder gst,i usually shop on ebay,the ones on there do not come with a weighted **** to match.anyone know where i can get the combo?
Old Oct 5, 2005 | 10:38 PM
Spyderman9803's Avatar
the b&m is worth it. you get the adjustability between two different settings...30% & 50% i beleive.
Old Oct 5, 2005 | 11:40 PM
Im scared to keep my foot in the gas when I shift since this GSX isnt mine... If it was mine I wouldnt have a problem doing it
Old Oct 6, 2005 | 10:39 AM
is'nt that bad to do,staying on the gas between shifts?
B.e.R.a.T
Feb 13, 2007 11:44 PM
whitestallion10
Jan 18, 2005 01:35 AM
JoJoClipse
Sep 28, 2004 10:54 AM
Prototype_fabs
Aug 15, 2004 03:27 AM
Prototype_fabs
Mar 22, 2004 01:41 AM
