short throw install
Old Jan 10, 2007 | 09:08 PM
jaydawkins's Avatar
Default short throw install
Im nwe to this but has anybody installed a short throw shifter in a 96 eclipse RS? Maybe can give me some advice or instructions on it. Would appreciate the help.
Old Jan 10, 2007 | 09:17 PM
Default RE: short throw install
its pretty simple. Just take off the console. And then youll see everything there. Just look atthe parts you have and what is there. Its just a direct swap of parts except the short throw is a little different shaped. I think its only a couple bolts
Old Jan 10, 2007 | 09:23 PM
jaydawkins's Avatar
Ok. Thanks I will do that.Another question. I got a lot of mileage on my car (it was used)so I want to do and engine rebuild. Should I also change all the gaskets or should I just get a new engine?
Old Jan 10, 2007 | 09:35 PM
how many miles. General maintanace is really all thats ussually neccessary like changing fluids, oil change, tune up, ect. Unless there is a problem with the engine, mileage isnt reallya problem. The onle thing that goes on those engines alot is the head gasket. but there isnt a reason to do that until its a problem.
Old Jan 10, 2007 | 09:40 PM
jaydawkins's Avatar
Its got 190.000. Mostly highway milage for this guy I bought it from. It isnt over heating or anything but I think I smell antifreeze from the exhaust but not by the engine. Plus is has a clicking noise a little.
Old Jan 10, 2007 | 11:59 PM
BlackMurcielago's Avatar
The clicking noise is probably lifter tick. How well did the last person take care of it.
P.S if you get a new engine try to get a 6-bolt
Old Jan 11, 2007 | 12:09 AM
Nubiebubie_GSX's Avatar
There no point for the 6 bolt .. His RS isn't the turbo 4g63. Unless ur down for spending lots mollah..
Old Jan 11, 2007 | 12:32 AM
5Tizzle's Avatar
If you can do the work yourself, a rebuild will cost very little.
Old Jan 11, 2007 | 01:11 AM
jaydawkins's Avatar
Well I was looking at machv.com and they have the rebuild kit for $549 but I will have to get the cams and pulleys seperate? What kind of cams should I get? Stage 2 or 3? I'm not sure what the difference is but they are $500 and the Pulleys are $200. Is that a good price for everything? If you have any recommendations let me know.
Old Jan 11, 2007 | 02:04 AM
estraw's Avatar
stage 2 should be just fine, unless you want to turbo it or something, all stage 3 will do is give you a rougher idleand maybe a couple extra hp, nothin that noticable tho
