short throw install
Old Jan 11, 2007 | 09:33 AM
Default RE: short throw install
getting upgraded cams is really a waste of money. Id say just save your money for one of two things. Turbo charging the RS, or buying a turbo car. Also from the mach v site, i believe that all you need is the engine gasket set. All the other stuff that comes in the complete engine rebuild like pistons you dont need. So if your hell bent on rebuilding the engine then just get the gasket set. And also your gonna need to have someone do this for you if you dont know how, so thats not cheap labor.
Now on the subject of the antifreeze, do you have any white smoke coming out of the exhaust. Also check the bottom of your oil cap for alot of white crud. Just to make sure you dont have a bad head gasket.
Old Jan 11, 2007 | 01:06 PM
jaydawkins's Avatar
yes I do have some white smoke come out from the exhaust but not all the time. there is no white stuff around the oil cap. so doing a engine rebuild kit wont do much for it as far as hp? what about an engine rebuild and addin a turbo? but i heard adding a turbo means i have to change pulleys and what not a lot more often?
Old Jan 11, 2007 | 02:47 PM
honestly i wouldnt turbo the car. Your better off just saving the money on that. But for making the car more reliable i think just the gasket kit would be enough, you dont need the entire engine rebuild kit. And engine rebuild is more for reliability. Now and engine build up is a totally different thing. Which has to do with upgrading stuff, like cams, pistons rods, valve springs, ect. But this to me is useless in your car. It would be a waste of money. Put it this way, unless you plan on spending around 3-4k to make your car fast then just stick to the bolt ons like intake and exhaust. Anything else would be a waste. But rebuilding an engine is never a waste cuz essentially your putting the miles on the engine back to square one. But before you start wasting money on stuff i urge you to do a compression test because then youll know if you even really need a rebuild or if you have any leaks.
Old Jan 11, 2007 | 04:03 PM
jaydawkins's Avatar
so maybe just change the gaskets on it? some racing headers, intake, exhaust with high flow cat or something? now what about the internals. like that clicking noise, maybe change the lifters?
Old Jan 11, 2007 | 04:48 PM
jaydawkins's Avatar
can i put the 4G63 Cyclone Non-TurboEngine in there to replace the old one? Fairly priced from JDM Motorsports. 380 plus shipping which the shipping is whats going to cost a little coming from japan.
Old Jan 11, 2007 | 05:09 PM
no you cant put a 4g63 in that engine bay. at least not cost effectively
Old Jan 11, 2007 | 05:35 PM
jaydawkins's Avatar
so what engine would be good to replace it with? the website is www.osakajdmmotors.comcheck it out and let mek now what i could replace it with. I'm trying to do the simpliest thing possible.
Old Jan 11, 2007 | 08:28 PM
plain and simple...a 420a is all you wanna put in there
Evo2nv
Feb 22, 2008 07:38 PM
jaydawkins
Jan 10, 2007 09:06 PM
minping
Jan 6, 2005 09:53 AM
Prototype_fabs
Aug 15, 2004 03:27 AM
Prototype_fabs
Mar 22, 2004 01:41 AM
