signal switch broken
Old Apr 30, 2007 | 03:57 PM
GSXEX Knubbe's Avatar
Default RE: signal switch broken
ORIGINAL: silvercoupe97
ORIGINAL: GSXEX Knubbe
actually, while we're talking about signal switches ...
why is my left turn signal blinking faster than my right one ?
One of your bulbs is about to blow on that side.
[:-]really ... i gotta get that checked out.
Old Apr 30, 2007 | 07:39 PM
silvercoupe97's Avatar
The filament/coil is starting to melt onto the other windings, thus lowering the total resistance in that bulb and that side of the circuit, thus a fast turn signal.
Just take out each of the turn sig bulbs and have a look or just replace them. For the rears, I'd replace both sides or you may get one side brighter than the other syndrome.
Old May 1, 2007 | 12:27 AM
yeah i just checked them out, removed them, adjused them, played with them ...
its doing awesome now.
but the bulbs are different from the others ... the other one has like 6 small led's surrounding a big bulb, and this one looks like it came from a lamp.
Old May 1, 2007 | 01:39 AM
...so, one side has an LED and the other side is a regular bulb? Why? Why aren't both sides the same? Just to be "Monk-ish" I'd replace the regular bulb with the another LED.
Old May 30, 2007 | 10:11 PM
djfrog2001's Avatar
My turn signal lever is shot so I was wondering where did you get you replacement and how much was it?
Old May 30, 2007 | 10:33 PM
Kaede.Noir's Avatar
Ok, you are my saviour once again silver, which is the relay and the flasher module on the 2g to get em checked? cuz like i said in a post a LOONG while ago, i have messed up signals haha
Old May 30, 2007 | 11:29 PM
ORIGINAL: djfrog2001
Cheapest place is the junk yard.
Explain "shot". It could be a simple fix and that's why I ask.
ORIGINAL: Kaede.Noir
Can you post the link to it KD? I'll post a little in here, but I'd like to see the original issue.
According to CAPS
[IMG]local://upfiles/10268/87FAE8414C734EC4AEF943964E1CE45B.jpg[/IMG]
..but according to my manual...there's a flasher unit under the dash under the driver's left side knee protector in that multi-purpose fuse panel
Old Jun 2, 2007 | 02:29 PM
tjbiker031's Avatar
well i went to Rockauto.com and it was pretty cheap, $58.79...thats the cheapest new headlight/ blinker switch i found.
Old Jun 2, 2007 | 04:12 PM
ORIGINAL: tjbiker031
Have you installed it yet? Did it fix your issue?
Old Jun 3, 2007 | 02:22 PM
tjbiker031's Avatar
yea i put the new switch in and i actually have blinkers... i tried to fix the old b4 i ordered a new one with no luck.
