signal switch broken
ORIGINAL: silvercoupe97
One of your bulbs is about to blow on that side.
ORIGINAL: GSXEX Knubbe
actually, while we're talking about signal switches ...
why is my left turn signal blinking faster than my right one ?
[:-]really ... i gotta get that checked out.
The filament/coil is starting to melt onto the other windings, thus lowering the total resistance in that bulb and that side of the circuit, thus a fast turn signal.
Just take out each of the turn sig bulbs and have a look or just replace them. For the rears, I'd replace both sides or you may get one side brighter than the other syndrome.
yeah i just checked them out, removed them, adjused them, played with them ...
its doing awesome now.
but the bulbs are different from the others ... the other one has like 6 small led's surrounding a big bulb, and this one looks like it came from a lamp.
...so, one side has an LED and the other side is a regular bulb? Why? Why aren't both sides the same? Just to be "Monk-ish" I'd replace the regular bulb with the another LED.
Ok, you are my saviour once again silver, which is the relay and the flasher module on the 2g to get em checked? cuz like i said in a post a LOONG while ago, i have messed up signals haha
ORIGINAL: djfrog2001
My turn signal lever is shot so I was wondering where did you get you replacement and how much was it?
Explain "shot". It could be a simple fix and that's why I ask.
ORIGINAL: Kaede.Noir
According to CAPS
[IMG]local://upfiles/10268/87FAE8414C734EC4AEF943964E1CE45B.jpg[/IMG]
..but according to my manual...there's a flasher unit under the dash under the driver's left side knee protector in that multi-purpose fuse panel
ORIGINAL: tjbiker031
well i went to Rockauto.com and it was pretty cheap, $58.79...thats the cheapest new headlight/ blinker switch i found.
