smic
Old Aug 7, 2008 | 08:26 PM
  #31
dsm1990gsx's Avatar
Default RE: smic
ORIGINAL: needsagst98
holy ***t i had no idea it could handle that amount. thanks man,
You have no idea, wait till you get a 6 bolt lol.
Old Aug 7, 2008 | 09:08 PM
  #32
needsagst98's Avatar
Default RE: smic
and that is on stck internals and everything? if i get a big t28 i can push 330 hp on the stock motor? if so that is sweet.
Old Aug 7, 2008 | 09:18 PM
  #33
dsm1990gsx's Avatar
Default RE: smic
Yep stock internals. 330hp should be no problem as long as you have supporting mods to go w/ your turbo of choice.
Old Aug 7, 2008 | 10:58 PM
  #34
sk8dudety's Avatar
Default RE: smic
i wouldnt suggest anything over 350 with stock internals... but you have to make sure you have all of the supporting fuel mods and everything first or else you'll fu(k up your motor
Old Aug 8, 2008 | 12:28 AM
  #35
silvercoupe97's Avatar
Default RE: smic
You also don't want to try that on a ragged out motor.
Old Aug 8, 2008 | 12:37 AM
  #36
sk8dudety's Avatar
Default RE: smic
yea that too
Old Aug 8, 2008 | 09:53 AM
  #37
Default RE: smic
should i rebuild mine first and puta better clutch in it? i have a 145,000 miles. no engine noise or anything. runs perfect.
Old Aug 8, 2008 | 04:13 PM
  #38
dsm1990gsx's Avatar
Default RE: smic
Wait till you blow yours up then rebuild a 6 bolt. If its not broken dont fix it.
Old Aug 9, 2008 | 01:44 AM
  #39
sk8dudety's Avatar
Default RE: smic
that's kind of dumb... if you're going to upgrade it then it's going to break, why not pre-empt it? if you're going to rebuild it why not do it now? or better yet get a 6-bolt block and build that up then swap that in
Old Aug 9, 2008 | 02:19 PM
  #40
dsm1990gsx's Avatar
Default RE: smic
So he should rebuild an engine meanwhile the one in the car is running just fine, I dont get it? Am I the only who thinks this? You cant judge an engine just by how many miles it has.
If he was smart he should do a comression test (wet/dry) and leak down the engine to see what condition the rings, valves,ect... are in. imo
