So how do I solve lifter tick
Old Aug 24, 2008 | 10:50 PM
nyc95gst's Avatar
Default So how do I solve lifter tick
So I am wondering how to get rid of lifter tick. I read somewhere about swapping 3g lifters? Is that right? Can anyone tell me which lifters to use to replace my originals with in order to kill lifter tick. I also read this write up and I was wondering if this is correct, and if there was a better one with better pics?
Thx
Old Aug 25, 2008 | 05:53 AM
Default RE: So how do I solve lifter tick
thats about the best youll get for a write-up. As far as where you can get the revised lifters is here
http://www.store.partsdinosaur.com/product157.html
Old Aug 25, 2008 | 01:02 PM
nyc95gst's Avatar
Awesome. Is there anything else I can/should do while I am in there? Just FYI, I wont be pulling off the head. Thx
Old Aug 25, 2008 | 08:16 PM
well if you feel your valve seals need to be done its not a bad thing to do, obviously youll be doing the valve cover gasket
Old Aug 25, 2008 | 10:31 PM
nyc95gst's Avatar
Yea I already replaced my valve cover and all the gaskets. I had a leak so I had to do it. I shoulda replaced the lifters then but that dint occur to me until I had the cover off. Lol Yea, I have to look into how to do the seals. Thx I want to install ARP head studs too, but I dunno if I can do that all in one day. Lol The writeups for that just confuse the crap outta me. I guess that'll be another thread.
Thx
Old Aug 26, 2008 | 06:41 AM
nyc95gst's Avatar
Aw man, I read the vfaq on replacing the valvestem seals. Do I really have to take out my timing belt and cams? Sorry if it's a noob question.
Thx
Old Aug 26, 2008 | 07:22 AM
yea, i was only suggesting it because i know alot of times those seals can be bad and youll have black smoke comming out the exhaust between shifts and such, because they will be leaking oil into the combustion chamber. But if your not really seeing any issues then dont even worry about it.
And to do the arp head studs, you can actually do the 1+1 method where you remove only one stock head stud and replace it with an arp one. Im not sure on the torquing procedure for this though. But i know it can be done to replace the studs without removing the head or components.
Old Aug 26, 2008 | 08:40 AM
nyc95gst's Avatar
Yea, I don't think I have any black smoke, but I'll check.
I can definitely dig the 1+1 method for the stud install. I know there is info in the manual, but is there any writeup with pics for a 2g install. Vfaq has info for a 1g and I dunno if they are the same.
Thx
Old Aug 26, 2008 | 11:28 AM
Ok after a little bit of reasearch this seems to be the correct way to do the install without removing the head from a couple of sources:
Specialty Tools
- Allen Head socket (to fit the stock and arp bolts)
- torque wrench
Steps
1. Drain the coolant (this is a must)
2. Remove one stock head stud and replace with ARP head stud. Only put the ARP stud in to hand tight. Dont put the nut on the stud yet.
**repeat step 2 until youve done all 10 of the head studs.
3. Now put on all of the head nuts to hand tight.
4. Torque down all of the bolts in the correct sequence according to the ARP instructions or repair manual. Make sure to torque the head studs in steps (ex. 60 ft-lb..then to..70ft-lb..then to..80ft-lb).
5. Fill the coolant
5. After approximately 50 miles, retorque all the studs to make sure they are at 80 ft-lb
Old Aug 26, 2008 | 02:12 PM
nyc95gst's Avatar
Dude you rock, thx for the info.
Randys
Aug 22, 2011 12:02 AM
cchrisj01
Jul 18, 2007 12:12 PM
paintballproam
Dec 23, 2006 01:28 AM
pcfig
Jun 9, 2006 01:11 PM
wildwest
Jul 9, 2004 11:54 AM
