Sound in my suspension
Old Jan 13, 2004 | 12:41 AM
97gstsleeper's Avatar
Default Sound in my suspension
hey, i have been noticeing this sound in my left front suspension. it started out as minor. but it has gotten really anoying. when i turn my steering wheel it will make a creek/grinding type sound or if i hit a bump sometimes but mainly when i turn. any suggestions or if it has happend to you . please leave a message for any info. i think it may be a joing or bushings?</P>
</P>
Thanks Paul</P>
Old Oct 23, 2004 | 04:16 PM
bcwetcoast's Avatar
Default RE: Sound in my suspension
I have a sound in my front left, it only hits when i go 40mph and higher. the pitch increases with speed and the sound is like a revolving hummmm then when I make a sweeping right and the left side dips i hear a grinding sound like krrrrrrrr just faintly.
Trying to isolate it but the mechinic said to look for the obvious first before you bring it into the shop to troubleshoot.
My 01 spyder got in a accident so who knows. alignment is good. steering components are good.
It does look like my left wheel is a bit forward in the wheel well compared to my front right. Hmm maybe a bit of a bend in the frame. who knows. if you solved it please reply.
ciao
bcwetcoast
Old Oct 23, 2004 | 05:27 PM
FatalJRA's Avatar
I have the same problem with my eclipse. I have a 98 spyder and when I turn to the right or into a driveway, I hear a grinding noise or like something is scraping. I had my car lowered, and when I brought it back to stock height is when I started having that problem. I have 18" wheels and I'm actually taking it into my mechanic on Monday. Do you have the stock size wheels, or are they bigger. My friend and I believe that it's my wheels rubbing against my springs when I turn. My friend had this problem with his Mercedes. If this is the problem, what you need are some wheel spacers. You probably only need a 5mm spacer for both fronts. I'll let you know if that's the problem with my car, and more than likely it is and in your case as well.
Old Oct 25, 2004 | 12:06 PM
mesaboogie18's Avatar
Sounds like your front struts to me. My friend's 97 GS makes a squeaky sound. My 92 LeBaron has worn out struts and it squeaks really bad.
Old Oct 29, 2004 | 03:31 AM
FatalJRA's Avatar
I took my car to my mechanic, he said that the rubbing was caused by my splash guard which is broken and when turning, the tire rubs against it causing a scraping sound. And Mesaboogie18 may be right about your struts, have you ever replaced them. I have Tokico struts which handle pretty nicely.
Pascal
May 12, 2004 02:59 PM
sixspeed
Mar 26, 2004 01:18 AM
quicken
Mar 6, 2004 11:37 AM
2fast4u
Sep 6, 2003 06:44 PM
ecmgremlin
Aug 22, 2003 11:06 PM
