spark plug with oil on it.How bad is it?
Old Jan 28, 2006 | 05:50 PM
jeffery0266's Avatar
Default spark plug with oil on it.How bad is it?
I am changing the plugs on my 99rs and the 1st plug had some oil on it the second and third was fine,the last plug had quiet a bit of oil on it.What am I looking at?
Old Jan 28, 2006 | 08:05 PM
Sanguinius's Avatar
Default RE: spark plug with oil on it.How bad is it?
This is directly from the Haynes manual.
OIL DEPOSITS:
Symptoms: Oily coating caused by poor oil control. Oil is leaking past worn valve guides or piston rings into the combustion chamber. Causes hard starting, misfiring and hesitation.
Recommendation: Correct the mechanical condition with necessary repairs and install new plugs.
Old Jan 28, 2006 | 10:29 PM
Thats where my hesitation problem came fromI bet.I looked at the oil and there was no water in it so I am assuming that the head gasket is not bad.I ordered the valve cover gasket and new plug seals.Is there anything anyone can think of that I might need to do while I have everything apart?Oh yea,I picked up the Hayes manual today also.
Old Jan 29, 2006 | 12:23 AM
eclipse27's Avatar
Mine 95 rs is doing the same thing, i think its a bad ring . I've tried new plugs and gaskets a few times (trying to do cheap things first). So it may be a ring.
Old Jan 29, 2006 | 08:45 PM
I would definetely say the rings. I know it not the same type of car but my mothers honda just had its rings replaced for the same reason, there was alot of oil on only one of the plugs.
Old Jan 29, 2006 | 10:51 PM
Sanguinius's Avatar
Either the rings or valve guides but I would think the valve guides would wear somewhat close to each other so the other polugs should be getting oil soon too.
Old Jan 30, 2006 | 10:12 AM
get435's Avatar
do a compression test that will tell ya if the rings are bad if all that checks out fine def bad valve guides and this is a simple fix pull head off i would take it to a macinest have them overhaul the whole head with porting and polish it cost about 250-300 last time i had it done depending on if u go with titanium springs and retainers.
Old Jan 30, 2006 | 08:38 PM
I really appreciate all the feedback and I will get a compression test on it tommorrow and see what happens.Will it hurt the car to be driven in the condition it's in for awhile?
Old Jan 30, 2006 | 10:52 PM
eclipsed4u's Avatar
nobody mentioned a blown head gasket? oil in the spark plugs and hesitation are two symptoms of a blown head gasket.
Old Jan 30, 2006 | 10:54 PM
It's not smoking at all out of the tailpipe,I checked for water in the oil there is none
