spark plug with oil on it.How bad is it?
Old Feb 2, 2006 | 12:52 AM
  #21
Sanguinius's Avatar
Default RE: spark plug with oil on it.How bad is it?
LOL Damn the bad memory... Yeah it should be between 130-150 PSI
Old Feb 2, 2006 | 12:56 AM
  #22
jeffery0266's Avatar
iight,thanks.I will talk to him about it tommorrow.I told him to keep the car till in the morn.The work is already done.Damn.
Old Feb 2, 2006 | 10:06 AM
  #23
get435's Avatar
let us know if it was at 50 or 150.
Old Feb 3, 2006 | 02:07 AM
  #24
It turned out to be 155.I havn't drove it much today,it feels like it still has the hesitation in it from a dead start.I think it still has a leak somewhere.
Old Feb 3, 2006 | 05:09 AM
  #25
Sanguinius's Avatar
Have you changed/checked plugs/wires lately?
Old Feb 3, 2006 | 01:14 PM
  #26
Yea,I just replaced the plugs,thats how I found the oil on the plugs.I changed the wires at the same time.
Old Feb 5, 2006 | 09:57 AM
  #27
get435's Avatar
Well if your chambers check out @155 you have good rings now seems like a head rebuild and u will be fine. I would suggest a local machine shop worse case you buy a new head for $500.00. but when you take the head off check the head gasket just make sure it is not damaged if it is than tat may be the problem but wont hurt to get head overhaled while it is off.
Old Feb 6, 2006 | 11:35 AM
  #28
eclipsed4u's Avatar
once the head is pulled off, check to see if the head gasket it bad. i am 99% sure that was your problem
Old Feb 7, 2006 | 05:32 PM
  #29
Alright,I took the car to a place to talk to a guy about getting a valve job done.He told me that before I jerk the head off it would be a good idea to get a leak down test done.Then I went to talk to another guy about the test,the more he heard he said that it sounded like something in the EGR system.He wants to do a diagnostic test on it before anything is done.Could my problem be in the EGR system or should I find another mechanic???
Old Feb 7, 2006 | 05:37 PM
  #30
eclipseonjuice's Avatar
I bet it is a simple leak in the seal of the valve cover. That is the most logical reason without getting so serious.
